JD R sheet metal advice
Adam Koch
02-11-2006 17:46:17
I'm trying to locate the material used to keep the hood from rubbing the grill assembly, and rear fuel tank cover. what is it, where can I get some? Is there any thing else I can use? Thanks in advance
Adam Koch Aviston Illinois
Adam Koch
02-12-2006 16:23:11
 Re: JD R sheet metal advice in reply to Adam Koch, 02-11-2006 17:46:17
Thank you guys for the info, you definatelly gave me a starting point. I have not checked My JD dealer yet, But I will monday. Thanks again Adam Koch Aviston Illinois
Mark Anderson
02-12-2006 07:29:37
Correct Connection
Brand0n
02-11-2006 23:35:11
If you're refering to that "compressed rope" looking material you will find it in the "resto-world" of antique and collector cars. A good place to look would be Year-One. I remember this because my fathers 1936 Chevrolet Business Coupe used this material between the side hoods and body metal along with the trunk and door seals. Most cars prior to around World-War II used this material as butyl rubber was not a perfected reality and even the cars of the early 50's used this material.
My R is sporting a piece of rubber hose captured under a layer of duct tape, was cheap and available and the redneck way to fly!
Brandon
DonR
02-11-2006 20:38:08
I got mine at the local jd dealer.
Diesel Man
02-11-2006 19:01:28
Well we used some on our R and right now i cant seem to remeber were we got it i will do some cheeking and see, i will let you know if i find out were to get it, did you check the local JD dealer?
