Positive ground
johndeereboy
02-11-2006 11:00:14
Which is better for an A. Positive ground or negative ground? And if you have one that is positive ground how to you change it?
John T
02-11-2006 12:59:02
 Re: Positive ground in reply to johndeereboy, 02-11-2006 11:00:14
Boy, All 2 cylinder Deeres came from the factory POSITIVE ground. In the event one were reversed the ammeter would read bass ackwards UNLESS its leads got reversed. Also if the ground is changed coil leads should also be swapped and the genny would have to be repolarized to the new ground.
John T
