4020 roosa master pump leak - jdemaris
unlkid
02-11-2006 09:16:47
I have '69 4020, 7000 hrs, with roosa master CBC633-18AL pump. One injector was bad and the others weak so I had all 6 replaced. The tractor runs good. Now the system pressure is greater and I have leaks at the injector pump. The pump appears to have a rack and pinion speed mechanism. I am getting leakage around the horizontal pinion shaft that the pump arm is bolted to. The most leakage is coming from where the vertical 'tube' mates with the top of the pump housing. There appears to be a weathered o-ring where the tube fits into the housing. Is this something that is fixable without having to remove the pump or have a complete rebuild? Do you have detailed schematics of CBC pump? Thanks in advance.
B-maniac
02-11-2006 10:08:36
 Re: 4020 roosa master pump leak - jdemaris in reply to unlkid, 02-11-2006 09:16:47
Yes the shaft has/needs O rings and yes it has to come apart to replace them. If you are satisfied with the performance the way it is ,you can just take the top off and replace the rings,just try not to get anything out of adjustment while doing it.Anything you loosen,mark and tighten in same spot. LOL
unlkid
02-11-2006 10:53:49
 Re: 4020 roosa master pump leak - jdemaris in reply to B-maniac, 02-11-2006 10:08:36
Thanks for the info. I consider myself an above average mechanic but have never torn into an injector pump. Is the vertical tube pressed in? Is it threaded and screw in? Keep in mind I have never even seen a schematic, so I am not familiar with the parts and how it is put together.
Bob
02-11-2006 11:38:20
 Re: 4020 roosa master pump leak - jdemaris in reply to unlkid, 02-11-2006 10:53:49
third party image
Is this it?
unlkid
02-11-2006 12:03:00
 Re: 4020 roosa master pump leak - jdemaris in reply to Bob, 02-11-2006 11:38:20
Yes, the schematic shows the pump I have. Refering to schematic, replacing the o-rings (14) on the pinion (15)looks simple enough as long as a guy makes sure the same gear tooth meshes with the rack the same. Replacing o-rings (7) on part (8) requires a little bit more dismantling. I'll have to take a look at the pump to see how easily the top comes off. Do the bolts holding the banjo fittings to the pump also hold the top (5) on? I really appreciate your help. Right now I can't afford to get an exchange rebuilt pump. I just put $500+ in the injector work. Thanks
Mike M
02-11-2006 12:55:30
 Re: 4020 roosa master pump leak - jdemaris in reply to unlkid, 02-11-2006 12:03:00
You don't want one of those rebuilt anyhow. Best to change it over to the other style pump if anything major is needed.
