3020 trans
deerefarm
02-10-2006 19:36:29
On a 3020 syncro- range transmission in either of the reverses (1r or 2r) the tractor moves ever so slightly and it grinds. The forward gears seen to be fine. we have been told it is a variety of things most common is the linkage or the fork. Any advice would be appreciated.
thanks
1acewrench
02-13-2006 14:18:53
 Re: 3020 trans in reply to deerefarm, 02-10-2006 19:36:29
Parts can be purchesed at your local JD dealer
drdugosh
02-12-2006 04:40:50
Your tractor will have to be split.
The top transmission shaft removed and repaired.
wimpfarm
02-11-2006 08:05:25
Sounds to me like the synchronizer"s for rev is out, not that uncommon & not real cheap to fix .
Terry..... ..
deerefarm
02-11-2006 10:17:10
 Re: 3020 trans in reply to wimpfarm, 02-11-2006 08:05:25
where can you find the syncronizer for the reverse?
