630 backfireing
George
11-21-1999 14:42:41
I have a 630 that has started backfireing from time to time. It seems to do it more when I first start the tractor and then stops for quite a while. Then it starts again. Any ideas of where I should begin to look for the solution to this problem would be appreciated.
RonMC
11-22-1999 23:45:51
 Re: 630 backfireing in reply to George, 11-21-1999 14:42:41
Does it backfire if the choke is on ? It could be running too lean, which will cause an ignition-like backfire. Possible plugging main jet - check the bowl for junk floating around.
rj gilmore
11-22-1999 05:46:48
frist place I would look is for a crack in the dist. cap can normaly see a fine black line where the spark is jumping. this happened to mine only another idea. RJG
DP
11-21-1999 19:33:39
George, before you tear anything down, go get a new condenser and install it. That is a symtom of a condenser going bad. My 630 does that and the condenser always has fixed it. Good Luck, Don
STMTS
11-21-1999 19:08:18
Might be you mechinical advance under the point plate in dist. your supposed to put a couple of drops of oil in the center of the rotor shaft from time to time But nobody remembers,Also could be a broken valve spring.
juan
11-21-1999 16:54:30
make sure you check the ignition system over really good. it may be a bad plug.
Tugboat
11-21-1999 15:27:33
Sounds like you may have a valve that sticks partially open from time to time. Are the valve springs in goob shape? Tugboat
