Hay Conditioner
Nancy Howell
02-10-2006 13:41:07
In our shopping around for a baler, I ran into several "conditioners". Since we have never baled our own hay before, I would like to know the purpose of a conditioner. Thanks!
johns48b
02-11-2006 06:49:21
 Re: Hay Conditioner in reply to Nancy Howell, 02-10-2006 13:41:07
having run conditioners with both rollers metal or one metel one and one rubber one i found the two metal rollers did the best work, although both will do. if your going to buy a conditioner buy one that cuts the hay using rotating disk. check to see if the bottom of the disk have any holes welded up in them. holes in the disk bottoms let the oil run out and ruin the gears that drives the disk.
RalphinWI
02-10-2006 21:12:25
Name: RalphinWI (Reserved Name) E-Mail: Subject: Re: Hay Conditioner
In Reply to: Hay Conditioner posted by Nancy Howell on February 10, 2006 at 13:41:07:
Body of Message:
The best of the lot, was the first conditioner (actually a crimper) made by John Deere. Intermeshing teeth put a kink in the hay stem about every inch. It could be hooked behind a # 5 mower, but if either mower or crimper clogged, they were both clogged by the time one stopped. We used to follow the A and a # 5 one round behind with an 8N and the conditioner. With two sons in the mid fifties, Dad had cheap help, besides it kept them out of trouble until the hay got dry. Every once in a while the miserable PTO on the 8N would grab the swath and wrap it about the PTO. Stopped you dead in a few feet. Made one into real believer about shields. We soon built a shield to isolate the PTO shaft from the hay field. Dad soon took a bale back to the dealer. A farmer would come in. Whose hay is that? How did he make it? Order me one!
WyoDave
02-10-2006 15:15:22
Old is on the right track. If its just a conditioner it doesn't cut hay. It runs already cut hay through a set of rollers that crushes, or cracks the stems of the plant allowing for moisture to more easily leave the cut crop which makes it dry faster. There are also mower conditioners, or moco's, or haybines (different marketing names depending on the brand) that both cut and condition the crop at the same time which is what Old is talking about.
David
old
02-10-2006 17:19:15
 Re: Hay Conditioner in reply to WyoDave, 02-10-2006 15:15:22
Dave, yep forgot about the type that just rolls the hay, don't see them in this area much if any, shoot I have never seen one around here.
old
02-10-2006 14:22:46
What it does is cuts the hay and also helps it dry faster becuase the hay runs threw the rollers and the water gets squeezed out of the stems. It can cut drying time in half which also says you trouble if its calling for rain.
