Hydrolic Oil for 35 B JD?
Wyatt
02-10-2006 12:12:18
Hello,
I'm new at this and was wondering if I can use Hydrolic oil in my transmition instead of 90 wt? I just had it all apart and cleaned it all out, put new seals in. Will Hydrolic oil work? Thanks.
old
02-10-2006 14:25:46
 Re: Hydrolic Oil for 35 B JD? in reply to Wyatt, 02-10-2006 12:12:18
Yes you can, but only if you want to hurt the tractor and have bearing etc go bad on you. What I use in my 1935 B is 80W-140 that way it works for all weather. Hyd oil is not made to the stress that there is in a rear end of a tracotr like that one.
F-I-T
02-10-2006 14:15:44
Wyatt:
You stand a fair chance of it leaking quite a bit, as the gaskets of the day were pretty porous, plus, hydraulic oil won't have some of the EP additives that are in gear oil. And last, the gear oil will cling and stay with the straight cut gear teeth, while hydraulic oil will be more apt to run off.
If it were mine, I would install 90wt if it is a northern tractor, and 140 wt if it is a southern tractor.
Frank
