Hello F-I-T
txgrn
02-10-2006 08:26:36
Hello,
About 4 pages back you made a comment about what I said about my 4010's cuid.....and yes I got it from tractordata. I said 300 and you said 380 or may have had the 4020 kit to up it to 400 or 404 thereabouts.
I would really like to know the correct answer to this because of the way I use the tractors.
The 10 is plenty stout and has a FEL (quick release bucket) and the 30 has a cab and 1000# of FEWeights. So I kinda figured the extra weight on the 30 balanced out the difference (I thought) in cubes.
The 10 has had plenty of hours on it and it had to have been gone thru for as good as it starts and runs for as much wear as it has. Have no way of knowing if the go thru included a 4020 kit to up the cuid. Dunno.
Thanks,
Mark
F-I-T
02-10-2006 08:44:31
 Re: Hello F-I-T in reply to txgrn, 02-10-2006 08:26:36
Mark:
I thought Igave you the correct answer...
The 4010 was a 6 cylinder engine with right at 380 cubes. When they came out with the 4020, the bore was increased on the 4010 engine so that it was now 404 cu.in. Subsequent engine kits offered for the 4010's used the 4020 pistons and liners, so by now one would think that every 4010 ever made has enough hours on to have got at least one major overhaul, so most if not all 4010's today are 404's.
Here's a bit of a blurb from another site:
...First tested at the University of Nebraska in late September and early October of 1963, the 4020 diesel developed 91.17 PTO horsepower. Its six cylinder engine�s 4.25 x 4.75 inch bore and stroke gave the tractor 404 cubic inches. The extra eighth-inch bore and corresponding 24 more cubes gave the 4020 about seven horsepower more than the 4010. Interestingly enough, the 4020 diesel�s fuel economy rating was actually less than the 4010�s by .77 horsepower hours per gallon.
Frank
Mike M
02-10-2006 09:49:44
 Re: Hello F-I-T in reply to F-I-T, 02-10-2006 08:44:31
I don't know ? Everything you stated sounds right to me from what I've heard over the years.
I can even see the extra fuel usage as more cubic inches usually = more fuel to feed it.
