520 manifold removal
Ferd
02-09-2006 18:41:19
Is there much chance of removing the manifold without snaping the bolts off in the head? Looks like it's been on there a long time. It has a hole through it on the LH side where it feeds into the intake - in front of the hot / cold valve. Looks like it just burned through.
Mike M
02-10-2006 07:09:10
 Re: 520 manifold removal in reply to Ferd, 02-09-2006 18:41:19
I once had a 530 where some hack drilled out his broken bolts off center at an angle (from having the hood and all on)and too deep ! Went into the water jacket ! I had one heck of a time getting that one to stop seeping antifreeze out the bolt hole. I could not find a sealer that would handle the high temp.in that area. I ended up taping the hole down in there putting a setscrew coated with JB weld to plug the hole then I could put the manifold and bolts back in normally this seemed to hold well.
I usually like to just pull the cyl. head and manifold off together then take them over to the work bench where I can work on them. In most cases that head hasn't been off in many years if at all and is in need of a valve job anyhow ! If I have any bolts break off (almost a given) I just set that head up in my milling machine on an angle plate then drill them out with an end mill. This is the BEST way to get out broken bolts ! Then while in there put in a fly cutter and take some passes accross the top and true up where the gasket surface has eroded away.Once in awhile you get one really eroded away and have to build it up with weld first.
CalJim
02-09-2006 22:44:27
Ferd,
The Manifold bolts on my 44 B were so bad
the stud and nut were smooth and rounded.
Apply torch until RED HOT,then squirt with
water.(I use an old soap bottle).You may
have to do this a few times. The shape of
the nut should now be good enough to get a
wrench on. Be patient, go a couple turns
then back off. Hope this does the trick. CalJim
MikeinKy
02-09-2006 19:40:33
I have removed several and have yet to break a bolt. The middle bolts usually come out easy. The outside bolts are where you can heat the head enough to loosen them. As for a socket, the above reply is basically correct. I have a set of sockets made for rounded off bolts and they are a life saver for any exhaust bolts. I have two sets. One is from Mac tools and one is Craftsman. I have had good luck with both. The Craftsman set comes with a case and every other socket. You have to buy the other half of the set seperately. I think the total is about $40.00, but it is worth it. The Mac set was $120.00. The craftsman set works as good so far. With this method and tools I have had good luck.
Carl NY
02-09-2006 19:25:20
Ferd, I hate to tell you, but the chances of getting the mounting bolts loose without snapping at least one off is slim. Usually the head of the bolt has changed size due to heat, so finding a wrench or socket is a problem. I have found that using a socket with a breaker bar allows a back & forward motion to loosen the bolt & allows alittle more torque. Good luck.
