1938 B Gas/Governor Issue ??
Ron Ouimette
02-09-2006 17:10:40
Recently restored a 38 B and it runs and starts fine but when I increase the throttle above half to full the engine starts to slow then speeds back up again as if it were running out of gas, it continues to go back and forth until I let up on the throttle and it runs smoothly at a lower setting. Not sure what to look for or check, can someone help. Thanks Ron
Ron Ouimette
02-11-2006 13:01:12
 Re: 1938 B Gas/Governor Issue ?? in reply to Ron Ouimette, 02-09-2006 17:10:40
Thanks for the info guys, I'll try these things and let you know how I did, the temperature at home just went below 0 last night,will wait until we get above freezing, I'm in upper NW Vt along the Canadian border. Ron
F-I-T
02-10-2006 09:57:46
Ron:
If it were me, I would first open the petcock on the carburetor and drain fuel out of there for a good 30 seconds, and make sure that a pencil-sized stream was maintained. This will ensure that you are not running out of fuel. Unlikely, but it's an easy test, and cheap, as long as you catch the fuel and dump it back in the tank.
Since it starts and runs fine at lower speeds, you might have a nozzle chamber problem like Mike mentioned, which could cause the carburetor to surge from "I have no fuel" to "I got the fuel!" Or you might just have another problem that occurs a lot on thesee old ones, a governor that is hunting.
The easiest way to check for this is remove the cotter pin form the speed controil rod in the carburetor butterfly so you'll be able to remove this rod from the hole while it is running, then start the tractor and let it idle. Let the throttle in the idle position. Now facing the carburetor while standing on the left side of the tractor, remove the speed control rod with your right hand and hold just a bit of pressure away from the governor so you can feel it working, while you operate the throttle shaft and plate on the carb with your left hand. As you speed the engine up by opening the throttle plate, the governor speed control rod should exert a force so as to close the throttle plate on the carb (if it were connected). Now note if the engine runs smooth and steady when you hold the throttle plate in one position. If so, you have a governor/linkage adjustment problem. If it still surges, I would think you are looking towards a carburetor problem.
BTW, the speed control rod adjustment is pretty simple. Engine stopped, throttle lever to wide open position, hand holding carburetor throttle plate wide open, the speed control rod should be 1/2 hole short from connecting.
Frank
P Browning
02-10-2006 07:46:38
Ron -- There is a simple, no-wrench test you can perform on your carb that may be revealing.
Go to www.jdhpubs.com, select "Technical Issues". Scroll down to the bottom half of page 3 for the test outline.
(PatB).
WTW
02-10-2006 07:15:58
If carburetor has been cleaned and can not be adjust to correct condition and engine idles fine at "slow" idle speeds, I would rather doubt that your problem is in the carburetor. With engine shut off, disconnect throttle control linkage from control lever at governor leaf spring. Check for full unrestricted travel of carburetor shaft and governor for any binding or drag of carburetor or governor or control linkage interference with hoods / fuel tank / brackets. This drag will cause this scenario. Governor arm, carburetor and linkage should travel together from full stop to full stop of carburetor travel without any resistance. Pretty simple to check and better yet usually a simple fix. Good Luck, DW
Ravgardner
02-10-2006 06:33:20
The float could be sticking and not allowing anough fuel flow. Open the valve in the bottom of the float bowl. Should see and steady pencil size flow of gas out the bottom. Also could be lack of air flow. Check for mud wasp nests, mouse nests in the air stack. Disconect the carb from the air filter, start engine and try to speed the engine up to fast idle as a test.
Just a few thoughts.
Dave NE IA
02-09-2006 18:51:36
Ron, if you are wondering if it is indeed the carb you can try taking off the intake on the carb and spraying gas with a spray bottle with gas into it as you advance the throttle. Thus you are giving it more fuel like the carb should be doing. Just a way to zero in on the problem. Be carefull with the gas as it is sprayed because it is in its prime explosive state while in a mist. Window washer spray bottles may break down with gas--I use a WD hand spray bottle.
Dave NE IA
Mike M
02-09-2006 17:17:57
See if moving the carb. adjustments help ?
You may also need to clean out the carb. especally removing the nozzle up in the center and cleaning out all the little holes and the housing. This is where gas is to be stored for acceleration.
