2510 Value - Going thru divorce
Rusty Scupper
02-09-2006 14:22:59
Hey guys, need your help and honest opinion on what the value of the following tractor is:
JD 2510 Powershift
Gas
Wide Front (Cast)
Allied 7"loader
Tires - approx 50%
Now for the bad stuff: C1 clutch is out, and antifreeze in the oil. I know head is fine and I would suspect it is the sleeves and needs a rebuild.
Maybe I can give her the bad half - ie C1 clutch and sleeves, and I can keep the rest. I live in the midwest (WI) if that makes a difference. Thks
freddy
02-12-2006 11:03:13
 Re: 2510 Value - Going thru divorce in reply to Rusty Scupper, 02-09-2006 14:22:59
I would disagree about the 2510 not being a good tractor. I have used a 2510. The engine (gas) is very snappy and good power. Its just a smaller engined 3010. The tractor is so smooth and the power steering and brakes are excellent. I prefer it to my 720D. Must admit the 720 sounds better.
jturbo10
02-12-2006 09:23:49
Even if you spent big bucks fixing up the JD 2510 you would not have a tractor known to be a highly sought after item. Gleaning info from other JD forums, my research leads me to suggest that the JD 2510 has a less than stellar reputation for reliability and desirability. Although I have not owned or operated a JD 2510, I would not put my money into restoring this tractor. I would get what I could out of the tractor and use the proceeds to buy/restore a two cylinder or a 20 series New Generation tractor as the residual value would be much higher.
Mike M
02-12-2006 13:55:06
 Re: 2510 Value - Going thru divorce in reply to jturbo10, 02-12-2006 09:23:49
I think you got it confused with the 2010 ?
The 1010 and 2010 got the bad rap. The must not be that bad as an awful lot of them have survied. Seems to be alot of interest in them too.
tony from sw ohio
02-10-2006 16:37:07
boys i got the 2510 out of ky its not on the ads any more it was cheap
Mike M
02-10-2006 11:55:30
Before the lawyers and ex. get off to thinking it's worth big bucks. Go over to the photo ads and check out prices and print off some ads.Within this week I saw that fellow in KY had a 2510 DIESEL ran good clutch slipped for only $3950 or something like that. He also had a 3010 Diesel for only $3500 ? I'd tried to get them both but I don't have any extra cash. It sounds like yours needs alot of expensive $$$ engine and powershift work done. Go get a written estimate from a dealer to fix what you need done. Then go to the sales dept. and copy off the page from their used tractor value guide.I'm betting repairs exceed the value of the tractor. This will show them that by GIVING you the tractor they will actually in the end be causing you MORE financal grief long term.
weldon
02-09-2006 20:16:16
How much does it weigh? 20 centa a pound. it ain't worth much.Take bettern $2000 to fix her up if you gotta hire it done.
95EB
02-10-2006 04:29:02
 Re: 2510 Value - Going thru divorce in reply to weldon, 02-09-2006 20:16:16
Yeah, just scrap anything that costs more than 50 cents to fix, right? Never mind that it's a relatively rare tractor that even with problems somebody's going to be interested in.
