GP block question
Bob-Wyo
02-09-2006 10:25:58
Does anyone have a early (29) GP block our where they can see the bottom of the block to see if there is plug in there? I'm asking as after many years i'm getting a antifreeze leak there, head gasket area is bone dry so it's not coming from there but sure is coming from bottom of block and with the cast frame it is hard to see where it is actualy coming from is why i'm asking, and then it just might be a crack that is opening up after all thease years.
Thanks for any help you can give.
Bob
paul o
02-10-2006 08:01:36
 Re: GP block question in reply to Bob-Wyo, 02-09-2006 10:25:58
We recently had a leak in a 29 GP block where one of the bolts comes up through the belly pan into a boss on the block. The bolt is used to help hold the block in place. Thread locker products on the bolt would not stop the leak. Took the block out and found a hole 1/8 to 1/4 inch dia into the water jacket above the threads. Filled the area with a product similar to JB Weld, drilled and tapped the hole. Cured the problem.
Bob-Wyo
02-10-2006 07:20:36
Thanks for the come back guys, think Spoker and Mike are right, gave it the black pepper treatment right into the lower part of the block and no leaking this morning, afraid tho it's a temp fix. Thought it could be a old freeze crack that is just now opening up also. just didn't want to split it just now to look.
Hi Spoker my friend, well its pulling so so, went to some Firestone 30" tires and can't get them to bite for me and not allowed to do any cutting on them, sure tired spining out in 2nd and she can't hack 3rd. Have a pair of Steve Crum's stacks on it now so we can always go for show. LOL.
Thanks again guys,
Bob
Spoker
02-10-2006 04:19:51
Bob, I found a 37 A john Deere once that I thought I wanted to buy. After check the block on the bottom side I noticed a small dark spot. I touched it with my pocket knife and the blade went into the water jacket. So it might be that over the years it has rusted away from the inside out. Hows the D's pulling?
Maark
02-09-2006 13:33:30
I have a small bore block. It doesn't have any plugs in the bottom of the block. You might go to Walmart and get some Waterglass sealer. A friend of mine chased a water leak in a Waterloo Boy. Never did find it after having both the block and head checked. The waterglass stopped the leak. Also get it at a drugstore.
Mike M
02-09-2006 12:09:39
Or it could be like the unstyled B I worked on years ago. The bottom of the block had holes rusted in it.
