Is the inside thrust washer in there?
JDGMC
02-08-2006 19:19:17
third party image
I put in a post some time ago on this topic but still haven't put together the ambition to tear all the gears, the governor and the end main bearing cap off. I'm working on a 730D ES that had about 1/8" of end play before I started and I did find that the outer thrust washer was shot. I'm still stewing over whether I really have to take anything more apart to get at the inside thrust washer. Since they are about 1/8" thick, do you think I might be able to get by with only replacing the outer one. I'm going to attempt to attach a photo to this message but I've never done it before. I'd appreciate more input. Thanks. JDGMC
Kevin L.
02-09-2006 11:59:36
 Re: Is the inside thrust washer in there? in reply to JDGMC, 02-08-2006 19:19:17
think the inner thrust washer also has a tab on it and I would not want to jack the crankshaft to the left not knowing the placement or shape of the thrust washer. I would look, it's better to look now than have to replace the outer thrust washer because the inner was bad and cause the outer one's tab to move from the slot and have to replace the outer one again. Starter should be easier to remove than a pony motor and the gaskets from the top lid are part of the gasket set used to replace or check the main bearing..
JDGMC
02-08-2006 19:24:26
third party image
Well, I obviously don't know how to post a photo on this forum. I read everything I could but still haven't figured it out. The photo I'm working on is in the Parts & Pieces Gallery titled 1959 730D.
I'm going to try it one more time but don't expect any success.
Thanks again,
JDGMC
Mike M
02-08-2006 19:51:42
 Re: Is the inside thrust washer in there? in reply to JDGMC, 02-08-2006 19:24:26
third party image
Let me see if I can get it ? Which side of the crank is in the picture and how did you take the picture ? How much is removed ?
JDGMC
02-08-2006 20:00:38
 Re: Is the inside thrust washer in there? in reply to Mike M, 02-08-2006 19:51:42
third party image
I removed the electric starter and the bracket and took the photo of the flywheel end of the crankshaft through the hole under the bracket. What you see is the crankshaft end and the flywheel side main bearing cap. There is a gap between the end of the crank and the bearing cap but I'm hoping that the thrust washer may fit inside the bearing cap. I don't know if it would be visible from the top.
I've got a fairly small digital camera and just stuck it into the hole and took some shots. I've got lots more but most of them aren't that good.
Thanks.
JDGMC
Mike M
02-09-2006 04:37:10
 Re: Is the inside thrust washer in there? in reply to JDGMC, 02-08-2006 20:00:38
It's been awhile since I was in one of those,but I think there is a recess. But I also remember Kinda? I thought you should see a notch where the tang to keep it from turning sits also ? Fish around in the bottom and see if you find any pieces. I found all kinds of stuff in the bottom of mine. Things like gov. weights,pins maybe even thrust washers ?
It would sure be great if someone who has one torn down could take some shots of what's to be there.
Lee B
02-09-2006 04:15:46
I'm thinking you just need to go to the clutch side and push the crank to the left side, removing the gap. I don't believe there is an 'inside' thrust washer to begin with. The outside one is the flywheel spacer and is driven with the flywheel spacer pin which fits into hole drilled into the flywheel. As yours is damaged, possibly sheared neatly off at the crank surface, you may have not noticed or known about it?
F-I-T
02-09-2006 08:43:03
 Re: Is the inside thrust washer in there? in reply to Lee B, 02-09-2006 04:15:46
third party image
I think there is, and I think it is missing or at minimum deteriorated. You access that via the LH main bearing housing according to the parts book, after pulling the crankshaft gear.
BTW, the thrust washers I have installed in the earlier models miked about .060", so those are closer to 1/16" than to 1/8". If you are looking to take up 1/8" gap before washers, and if the newer models used thrust washers of the same or similar thickness, probably half is attributed to the inner thrust washer, and half to the outer.
Frank
720Deere
02-09-2006 07:33:58
The thrust washers have nothing to do with the oil slinger. There is definitely an inner and an outer thrust washer. Get a service manual and replace them both. It's not that bad of a job on an electric start unit.
I would not want to guess on the status of the inner thrust washer if the outer one has been destroyed. If the tractor has been run with the outer thrust washer missing or worn out, chances are that the crank has beaten the inner pretty good as well.
JDGMC
02-09-2006 14:56:53
 Re: Is the inside thrust washer in there? in reply to 720Deere, 02-09-2006 07:33:58
I don't know if anyone will still find this post but I do have the service manual and an IT manual and there isn't much of an explanation on how to replace the inner thrust washer. Neither of those manuals really impress me. Someone told me that I may have to heat the gears to get them off. From what I'm hearing though, I guess I'll have to suck it up and go in. Thanks for all the input.
JDGMC
720Deere
02-09-2006 19:02:14
 Re: Is the inside thrust washer in there? in reply to JDGMC, 02-09-2006 14:56:53
I will agree that some items in both the JD and I&T manuals leave a bit to be desired for the first timer. They were designed for mechanics with some basic training on the tractors. I find that studying both manuals and the parts catalog before I dig in really helps. Each manual tends to cover things just a little differently and then using the parts breakdown to see what needs to come apart, I have been able to figure out just about everything. For those things that still baffle me, I usually find the answers here or at Johnnypopper.
JD man in SD
02-09-2006 16:34:21
as i remebber the gear runs against the thurst washer. i always cleaned brg housing dried & applyed 3m yellow weather strip glue to housing & layed flat installed washer smooth side up lay flat plate on washer &add a little weight 2 or 3 lbs let dry over night then install;the washer will stay in place
Kevin L.
02-09-2006 19:16:42
 Re: Is the inside thrust washer in there? in reply to JD man in SD, 02-09-2006 16:34:21
still think you could open the lid to the left connecting rod and push the crankshaft to the right side a little and get a good idea of the shape of the inner thrust washer, as in if the tabs are there and if the washer feels smooth moving around on the crankshaft or inner bearing housing and under the bottom to see if the full washer is there. roll the left piston to the top and look with a mirror at the bottom side.
I have a 720D pony that has a broken outer washer and also has a broken keyway on the camshaft, so I'm in the same area that you are..
