Unsettled idiling on an 'A'
Elk Hunter
02-08-2006 18:16:22
I set the timing about perfect and have fresh plugs. I also rebuild the carb and have fresh gas. When she is sitting there idiling at low rpm's she keeps jumping back and forth from a smooth idle. It doesn't really miss and sputter it's more like she wont settle down. Like the governer wants to keep pulling in. Someone told me that the spring in the distributer base gets weak. Is this true or does it sound more like the governer is the problem. Any thoughts guys? -Tom
John T
02-09-2006 07:07:19
 Re: Unsettled idiling on an 'A' in reply to Elk Hunter, 02-08-2006 18:16:22
Elk, One way to tell if its a carb versus a governor problem is to remove the throttle linkage rod on top the carb and with a steady hand manually hold her at idle speed n see how she does then. If you can manually make her idle slow n smooth n sweet n even, then I suspect a overnor problem but if no change then I suspect a carb problem and/or a a vacuum leak.
Be sure theres no cotter key or other bindings or restrictions where the throttle rod fits to the carb and other places
See if the linkage adjustment on that rod to the carb is adjusted correct. With the throttle set wide open and the carb butterfly held wide open, the rod length should be about 1/2 hole short of fitting in, if not try that n see what happens.
At slow idle, the carbs lil top horizontal idle adjustment screw ought to be bumping up against the vertical stop spring, look at that.
Next to try at slow idle is use WD 40 or Carb Cleaner or an unlit propane torch and spray around the carb, especially its throttle shaft bushings, and its mount and around the manifold base looking for a vacuum leak. If she speeds up or smoothes you found a vacuum leak. Of course, also try adjustng the carb top idle needle, the initial rough in settign is around 2 turns out.
A single barrel carb isnt gonna idle as smooth n slow n sweet n even as the later duplex models, but if theres no vacuum leaks and the carbs set right and shes timed right, they ought to do pretty well. My buddys 1937 Unstyled A will idle so slow the mag starts snapping which is actually way to slow cuz its hard on the mag plus the cylinders n valves dont get oiled as well as they should in my opinion.
In cases where she wont idle down and hunts up n down constant and severe and the cycle repeats is often cuz the carbs idle passages are clogged up so the governor kicks her up to the power circuit then it shuts back down over n over n over.
John T
Machinery-man
02-09-2006 04:43:34
The hunting problem could be some wear in drive gears but most likely is in the carb. If it has properly been rebuilt, the hidden passage cleaned and main jets clean it should idle without major hunting, however if you lean out for smoother idling you will go lean on the acceleration. Most strong engine will have a rumble at the low RPM.
DickD
02-09-2006 01:06:11
Eli; I had a 52 A that did that. Tried everything. Shortly before I dynamited it to pieces, I took some silicone, and went all the way around the manifold intake gasket to check for leaks. It idled like a champ. Replaced the gasket--end of problem.
Mike M
02-08-2006 19:37:02
Or are you expecting an A to idle too smoothly ? Say like a 60 does ? I had a fellow drive me crazy over A once. Then I found out he also had a 60 and was comparing it to that. Also alot of people try to run them too slow. I think the idle is to be around 500 rpm. Not down slow enough to count the fan blades.
Then sometimes you just get one that a different carb. will settle it down. I also read where sometimes in the old days they would gap a spark plug with a nickle and that would settle some down. I tried it once,but didn't go quite that far of gap. It did seem to steady one of my A's out. I have since changed the carb. and regapped back to .035 and that worked too.
Elk Hunter
02-09-2006 03:00:12
 Re: Unsettled idiling on an 'A' in reply to Mike M, 02-08-2006 19:37:02
Thanks for the help. I'll try those ideas. I guess I will fet a new lil felt gasget for the throttle shaft too. Strangly enough my sons A will idle down where I can count the fan blades. I guess I just don't want him to have a better running rig than me LOL!! -Tom
