720 JD
Sam in Mod
02-08-2006 13:32:01
Has anyone overhauled a power take off on a 720? Is it complacatied to do. Does any one have a breakdown picture of one? Thanks Sam
Glen in TX
02-08-2006 15:47:54
 Re: 720 JD in reply to Sam in Mod, 02-08-2006 13:32:01
A I&T manual will cover it and they can print you off page or 2 of parts list at JD dealer.
mjbrown
02-08-2006 15:14:24
Changing the clutch pack is not that hard but most need to have the seal replaced that keeps transmission oil in the trany and out of the pto housing. To get at that seal requires removing the rear housing from the back of the tractor and that is a pretty big chunk of cast iron so some large lifting equipment is needed.
CRUSADER
02-08-2006 14:12:28
Take a look at your owners manual. It should have instructions for adjusting it. You may be able to get a few more years use out of it like it is. The process isn't that complicated and shouldn't take that long to do. Hope this helps and good luck.
Jim
