Heisler overdrive for A,B
Duane Larson
02-08-2006 09:41:38
Heisler advertised an overdrive unit for the 4-speed A and B, but has anyone ever seen one? It was apparently similar to the Behlen unit, but probably earlier. A search of the archives here didn't turn up any info.
Maark
02-09-2006 13:52:07
 Re: Heisler overdrive for A,B in reply to Duane Larson, 02-08-2006 09:41:38
I will look again when it is a little warmer.It was a little dark last nite when I looked. I will have to climb over a couple of tractors to get another good look. But, I'm sure it isn't marked on the side cover. The lever comes out the back, stands straight up, flip it side to side to engage and disengage. I haven't run it in quite some time, but seem to remember it would go 16-18 mph.
Maark
02-08-2006 16:34:22
Were the Behlen Overdrive units marked in any way? I have a 37A with an overdrive on it. I don't know what model it is though. It has no markings on the outside case. This tractor came with a Heisler head though
Duane Larson
02-08-2006 20:33:39
 Re: Heisler overdrive for A,B in reply to Maark, 02-08-2006 16:34:22
Maark,
I turned up some more info here from Mike. Apparently the Behlen unit has Behlen, Columbus NE cast into the housing, and the lever comes out of the back of the unit and engages to the left. The Heisler unit seems not to be marked, and the lever comes out the top and turns like the power take off lever.
Does this make sense?
Glen in TX
02-08-2006 10:32:40
The old Heisler ads I've seen barely mention those gears saying a overdrive of 2 speeds of 7 & 11 3/4 mph can be added. No pics either. Seems all their ads were more geared at marketing the 9 speed set up for the IH tractors.
Duane Larson
02-08-2006 11:55:09
 Re: Heisler overdrive for A,B in reply to Glen in TX, 02-08-2006 10:32:40
Hi Glen,
Other than the ads, the best lead I have is a line in very small print from the 1950 Central Tractor parts catalog that says "We expect to have Heisler Overdrives the latter part of February for John Deere Model A and B. Kindly write us for particulars". I have a set of CT catalogs from 1938-1969, and it never showed up.
Glen in TX
02-08-2006 13:53:23
 Re: Heisler overdrive for A,B in reply to Duane Larson, 02-08-2006 11:55:09
Duane, The info above was all I saw and latest I found in a Heisler ad just being about two lines for the JD in 1951 ad on page 100 of a I&T Catalog File book. It also said for A & B and other row crop tractors being made before 1940. Just called it a Overdrive Gear Package.
Vincent Etchen
02-15-2007 13:17:13
 Re: Heisler overdrive for A,B in reply to Glen in TX, 02-08-2006 13:53:23
I have a 36 JD Model A with a Heisler overdrive. The gears are missing, and was wondering if anyone had any to sell or knew anyone that I could contact about this? If someone had an entire unit in good condition, I would be interested in that too.
Thanks,
Vin
