70 gas elec cut out
brian in niowa
02-07-2006 20:10:21
My 70 will almost start at first and the lights will work but then it cuts out and the lights won't work. New coil plugs points condensor light switch wiring and battery. what next?
cv560
02-15-2006 09:57:00
 Re: 70 gas elec cut out in reply to brian in niowa, 02-07-2006 20:10:21
My son has a 70 diesel with pony start. He replaced the entire electrical wiring system. When we tried to start the pony, the voltagel dropped to zero everywhere, except on the battery. Turned out to be a bad ground from the new braided cable from the battery to the battery box. A little wire brushing and all was well.
John T
02-08-2006 10:17:14
Brian, Sorry, I just dont know????? It sounds a lil like a bad or loose or carboned ground or cable connection somewhere but that sounds too easy. Maybe remove n wire brush n reattach each n every battery n starter n ground conenction n see what happens. Also check the smaller wire from the starter switch (where big battery cable attaches) that leads up to the ammeter as thats a main voltage feed source. If it has a 4 terminal Voltage Regulator that has a LOAD terminal, make sure the wire is good from there up to the BAT input terminal on the switch. It may just be a bad battery cable or conenction, check those type easy simple things first n let us know.
John T
