Hard shifting 730 diesel.
mike 154
02-07-2006 18:49:47
This is the first 730 I've come across that I have trouble shifting from the left side gears to the right side gears. It will go in and stay on the left gears easily. But to get it to go in on the right side gears is very difficult. Can you guys tell me where to look? Thanks, again
Mike
mike 154
02-09-2006 11:30:19
 Re: Hard shifting 730 diesel. in reply to mike 154, 02-07-2006 18:49:47
Thanks,guys.
Mike
Hilltopper
02-08-2006 17:34:51
My 720 D did the same thing. I found everything adjusted correctly. I decided it was not lifting the o.d. lock when the shift is pulled all the way down on left side. The shift ball on the bottom of the stick looked O. K. I decided to grind the left hand slot a little longer so it could move far enough to lift the lock. This worked good until the tranny gets warm then I have to bring the shift down the left side as fast and far as I can then it will unlock. This seems to be a critical situation and I wonder if it would be possible to enlarge the shift ball some how. The easier way is to grind the left Quadrant some more. Hope this makes sense.
Mike M
02-08-2006 07:12:44
I guess I'd start by doing some adjustments. I think those later tractors have adjustments to be made inside the reduction cover to the clutch fork. These were to allow the pulley to slowly rotate just a wee bit so as to help mesh the gears.
If the lever it's self is hard to move then you may have a shifting fork problem like a worn pawl interlock not letting the pawl release enough ?
