JD B Carb Adjustment
MW
11-21-1999 10:04:13
What is the proper way to adjust the carb on model B? It runs like the choke is on and plugs carbon up and foul out, Also, how much compression #/sq in should it have? THANKS
John T
11-21-1999 10:42:50
 Re: JD B Carb Adjustment in reply to MW, 11-21-1999 10:04:13
MW, start initially at one turn out from bottom closed on idle jet and two on power jet. Then idle down slowly and lean the idle jet till she starts to die then open it out about one quarter turn or more from there. On the power jet, turn the throttle wide open, and richen (open) the idle jet till she starts to black smoke and run too rich, then close it down till she just stops black smokin. Then fine tune the power jet a little richer if youre running heavy loaded but run her lean as possible for parading. If the float level is too high or the float is a little leaky or needle valves stickin open, that over fills the bowl and she runs too rich also. Once the plugs (especially Champions) have been blackened or fouled, I would install a new set before doing the above. Ol John T in Indiana
