720 Diesel Main bearings
Chatermb
02-07-2006 16:00:47
I am working on a 720 diesel. There is some vertical movement in the crankshaft so it needs to come out, be ground and reinstalled with new mains of the proper size. The John Deere dealer here says I can obtain outer bearings but the parts books lists the centre bearing as obsolete.
I looked through a recent copy of the Green Magazine to see if there was a dealer advertising 720 mains for sale. But no luck. Can anyone suggest where I can find main bearings for a diesel 720.
The shop foreman asked about the flywheel which was loose on the crank and consequently worn. He was telling me that perhaps I could have a local machine shop build up the center hole of the flywheel and then remachine it so it fits tight on the crankshaft once again. I spoke to the machine shop and they have done this work on a JD flywheel. Has anyone had experience with fixing a loose flywheel this way? If the splines on the crank were somewhat worn did this fix work?
I was not that worried about the flywheel as I know I can obtain a taper lock flywheel. However this method could save me some dollars. I am finding that fixing Diesel 720's is not cheap.
Thank you for any advise you are able to give me.
Chatermb
02-08-2006 06:47:39
 Re: 720 Diesel Main bearings in reply to Chatermb, 02-07-2006 16:00:47
Thanks for the help. I'll contact Renaissance Tractor re the bearings.
I'll keep them in mind for the crank and flywheel. I think I had better measure the wear accurately before I start shipping all these parts a 1000 miles one way. Then I'll know what has to be done and if the locals can do it.
The governor gears look good however the gear that drives the governor off of the crank has some wiggle in its bearing. I can not remember what the service manual had to say about replacing the bearing and I don't have it with me. The tractor is in dad's shop a 100 miles away.
The bevel gear that drives the fanshaft is missing 4 teeth and needs to be replaced. One of the governor weights came off in 1965 and this is what we suspect caused the tooth damage. At the time the weights were fixed the gear appeared visually ok.
If I remember correctly there are two dowels that locate accurately the govenor case on the engine block.
Paul_IN
02-07-2006 16:44:56
Talk to Renaissance Tractor, they advertise in Green Magazine. 800-784-0026. They have the bearings you need and they also rebuild crankshaft splines so they can tell you if what you propose with your local machine shop is doable. I"ve not dealt with them, but have heard nothing but good stuff.
buickanddeere
02-07-2006 17:34:44
 Re: 720 Diesel Main bearings in reply to Paul_IN, 02-07-2006 16:44:56
As Paul stated. Just place the crank, flywheel, primary fuel pump, injectors, the entire injection pump(s) assembly, cam and followers on a pallet and ship to Albert. The price is fair and the work is excellent. There is a fix for the governor gears which can work loose and grind themselves to bits. The bearing body has to be staked securely into the block casting.
