JD B What year is it?
chris
11-21-1999 09:56:00
I just bought a model B and the serial # is 2?3585. The second digit was damaged enough you cant tell what it is. The guy that sold it said it was a 47, but I think it is newer than that. It has the 6 gear trans, electric start, hydrualics, standard size pto, the wider side frame rails, and battery under seat. It has no water pump, round axel housings [ no lettering ], and magnito ignition. I know the newer ones had square axel housings, a water pump, and a distributor, but I didnt know when they went in to production. Thanks for any replies.
mark
11-21-1999 10:08:08
 Re: JD B What year is it? in reply to chris, 11-21-1999 09:56:00
1947 serial number is 199744-209294. 1948 is 209295-230043. 1949 is 230044-253024. it is either a 48 or 49 as square axle came out in late 49 or 50. hope this helps.
