1958 WICO ad
Glen in TX
02-07-2006 10:42:40
Wico made more ignition units than just for JD. Anyone have some Wico XVD units for parts?
Duane Larson
02-07-2006 18:07:17
 Re: 1958 WICO ad in reply to Glen in TX, 02-07-2006 10:42:40
Glen,
Nice piece of info. I haven't run into an XHG of any type on a Deere - have you? I was a bit surprised the XB distributor was still there, but I guess it was the only flange mount one Wico made so they had to keep it.
Glen in TX
02-07-2006 18:31:11
 Re: 1958 WICO ad in reply to Duane Larson, 02-07-2006 18:07:17
Not sure how long they made the XB battery dist. but it was made in a 4 cyld. also on several other tractors also like Allis and a few others. Makes me wonder why they never made another style distributor for JDs except those DBs on the Duburque models.
I believe the XH-184 used on 4 & 6 cyld. Hercules JD combine engines would be a XHG type. Also was one used on Lycoming D combine engine. XHG type fired at 180 deg. in 2,4, & 6 cyld.
All others for JD 2 cylinders were the XH type was made in 1,2, & 4 cyld. to fire at 360, 180, or 90 degrees.
buckeye al
02-07-2006 14:37:15
Yes indeed WICO made mags for lots of engines. Once worked on a V4 outboard motor that had a tooth belt driven WICO mag in it. Belt had broken (mouse got in & built a nest over winter) & the owner replaced it but was three teeth off. Started but ran like crap & fouled plugs. Re-timed it & ran like a top.
Don't remember the model of the mag. Too far back.
Later.
Glen in TX
02-07-2006 18:47:57
 Re: 1958 WICO ad in reply to buckeye al, 02-07-2006 14:37:15
Not much telling and they did make a lot of outboard motor ignitions at one time. Never seen a belt driven one. Most every old dealer has parts for those kind collecting cob webs and dust.
Mike M
02-07-2006 11:19:29
I actually saw an engine with one of those XVD's on it ( I think ) It was a JD 4cyl. power unit.
Glen in TX
02-07-2006 11:40:33
 Re: 1958 WICO ad in reply to Mike M, 02-07-2006 11:19:29
Yeah you are right, there was a JD model 74 engine and JD 145 power units that used a 4 cyld. XVD mag. Mostly find the 6cyld. ones here that were once ran on large Waukesha or Continental irrigation engines and later on smaller 6cyld. Chevy or Fords.
