Factory paint on valve stems?
Ten-Twenty
02-07-2006 08:30:51
I have been studying old photos of original John Deere tractors and often (but not always) there is clearly yellow paint on the valve stems on the front wheels. What was the procedure for painting front rims? I know the inside of the rims were painted yellow prior to the mounting of the tires, but it would appear that some painting took place after the tire mounting to account for the yellow on the valve stems. Has anyone researched this issue?
msb
02-07-2006 19:19:03
 Re: Factory paint on valve stems? in reply to Ten-Twenty, 02-07-2006 08:30:51
Can't say about the 2 cylinder tractors,but Deere used flat steel wheels on the New Generation tractors when they went to the paint line.The drivers seemed to delight in spinning the wheels when they were driven off the assembly line.If the tractors didn't have a parts missing or reject tag on them (can't stop that line for any reason), then it was directly to the paint shop.The tagged tractors went to an area where the tractor was completed(sometimes drug away).One time I saw a 4020 with a reject tag and all it needed was a hose clamp tightened.
Rims were painted before the tires were mounted.The tires/wheels were installed after the green paint was cured.The lug nuts and rear wheel wedge bolts would have to been at least touched up after the wheels were installed. I would guess this procedure was also used on the 2 cylinders as well.Can't remember how the front hubs were handled.Think maybe they were painted just before the front wheels went on. Went on two or three factory tours when at Waterloo for diesel pump repair school.Very enjoyable and enlightening experiences since the tours were a bit more detailed and longer than the public tours.Last trip was in 1974 ,I think.
Ten-Twenty
02-08-2006 05:25:57
 Re: Factory paint on valve stems? in reply to msb, 02-07-2006 19:19:03
msb,
Thanks for the input!
