B wiring harness
Crude K
02-07-2006 07:17:41
Where can I buy a new wiring harness for a 52 B. This is a project tractor that needs new wiring before I can get it running to see what else is wrong with it. Can I just hot wire it to get it started for now. Any help would be appreciated.
Rich in Md
02-07-2006 11:54:49
 Re: B wiring harness in reply to Crude K, 02-07-2006 07:17:41
WWW.brillman.com
I bought a harness off of them two years ago when I redid my 49 B and I was vey pleased with their product, every wire marked and comes with complete installation instructions.
Tom N OK
02-07-2006 08:54:03
You can get wiring harness here. >Link
Never>Link tried them, just saw it on another post.
Tom
720Deere
02-07-2006 15:21:26
 Re: B wiring harness in reply to Tom N OK, 02-07-2006 08:54:03
I can attest to the quality of Agri-Services (that's who the wiringharnesses link is for)and their products. I have installed 3 of their harnesses and will be installing a 4th in the next month or so. High quality, very original looking and Jim is a great guy to deal with. He's even a John Deere guy himself that frequents these boards when he has time.
old
02-07-2006 08:22:15
Yep you can do the hot wire thing just to get it up and running. Just remember that if you do so its not as easy to shut it back down if you have trouble
Crude K
02-07-2006 12:56:53
 Re: B wiring harness in reply to old, 02-07-2006 08:22:15
I would like to get it running but don't have any wires to follow to get the distributor hot. Can you give me instructions on how to wire it with a new switch so I can just get it started.
Thanks for the help!
old
02-07-2006 13:32:57
 Re: B wiring harness in reply to Crude K, 02-07-2006 12:56:53
Well if its a battery ignition system you just run a wire from the battery to the coil and turn it over. Thats all hot wireing is.
Crude K
02-07-2006 13:47:38
 Re: B wiring harness in reply to old, 02-07-2006 13:32:57
Old,
It is a 1952 B with the battery under the seat. The dist is a wico and has one post on the outside of the dist that faces froward. My assumption was this post had a wire that went ot the switch. After looking at the switch one of the posts on the switch was broken off and the other wire from the switch looks like it is grounded to the frame. I don't know how this all works with a positive ground or if my assumptions are wrong. You know what they say about assumptions.
Kurt_JDB
02-07-2006 14:43:15
 Re: B wiring harness in reply to Crude K, 02-07-2006 13:47:38
Your WICO could be either a mag or a distributor. They look almost identical, especially if the mag has a stop post. If it is a distributor, the serial number tag will say XB 4001. If it is a mag it should say XH 1042.
The battery post for the distributor is also mounted on a fiber rectangle which is screwed to the body.
If it is a distributor, the battery post should be connected to the negative terminal of the battery, assuming that the tractor is still set up for positive ground.
Kurt
old
02-07-2006 14:26:22
From what you are saying it doesn't have a distutor. It has a mag on it, so all you need to do is turn it over with the wire removed from the mag. To shut it back off all you do is short out that place on the mag where the wire is.
Crude K
02-07-2006 14:35:40
 Re: B wiring harness in reply to old, 02-07-2006 14:26:22
Old,
Thanks for the help. That would explain the single wire and the fact that it had run before I bought it. Is the tune up for a mag the same as a dist points/condensor. I know a little about mechanics but nothing about mags.
old
02-07-2006 14:39:48
 Re: B wiring harness in reply to Crude K, 02-07-2006 14:35:40
Yep pretty much so, points and condenser. I don't know what the point gap is so I coan't help you there.
