B brass petcock
Crude K
02-07-2006 07:07:02
Can any one tell me what is the brass petcock on the cylinder block, bottom on the flywheel side is for. I can't find any referance to it in the manuals. The motor doesn't run yet and the petcock seems very loose from open to close. Can it be removed or is it adjustable to keep it in either position. My guess is a compression relief or drain for the block of some kind. Any help would be appreciated.
johns48b
02-12-2006 15:48:32
 Re: B brass petcock in reply to Crude K, 02-07-2006 07:07:02
i wouldn't replace them at all. if you overhaul the engine or try to crank it when its cold or the battery is weak you'll need to open them up to take the compression off the engine. they will probably be all right just as they are. mine work easy but never just open up on their own on my b
Tom N OK
02-07-2006 07:55:14
The compression release. Makes your tractor easier to start by having it open then closing it after it is running.
Tom
Walt in Jaxn Tn.
02-07-2006 20:35:30
 Re: B brass petcock in reply to Tom N OK, 02-07-2006 07:55:14
If it's a late styled "B" then the pet cock is under the block and in most cases forgotten. If you plan to battery start the "B" only (never hand start) then I'd replace them with pipe plugs. --Walt--
