JD1010 Manual Discrepencies
arice
02-07-2006 06:46:43
I have purchased both the owner's manual (OMT16142 A1) and I&T's Shop Manual (JT-21). The owner's manual says plugs on a gas engine are gapped at 0.025, but the shop manual claims the plugs are gapped at 0.015. Anyone know for sure which is correct?
jdemaris
02-08-2006 07:06:11
 Re: JD1010 Manual Discrepencies in reply to arice, 02-07-2006 06:46:43
All of my OEM Deere manuals and my IT manuals for 1010s and 2010s state the .025" plug gap. In reality, the engine doesn't care what the gap is as long as #1 it's not so narrow that the subsequent firing voltage is too low to cause combustion, #2 there is enough voltage available to jump the gap, and #2 the secondary system is insulated enough to handle the voltage without shorting. So, .025" is a good average setting with standard ignition components. If you had breakerless high-output ignition, and high quality wires, the gap could be increased.
Osage
02-08-2006 05:32:15
For what its worth, when I got by JD1010 the plug gap was very tight and it missed at little. Since the plugs looked near new and not having a manual I regapped to .030, it now runs great.
Thanks for the info, I"ll regap to .025
Osage
msb
02-07-2006 19:27:30
Maybe I&T shop manuals are like road maps.Cartographers intentionally make small obscure mistakes so they can copyrite their work.Correct plug gap is .025".
Hayfarmer
02-07-2006 07:07:09
I don't know for sure but know my 430 is gapped at .025. Think I would go with that. .015 seems awful tight.
