1942 JD A
frank van den d
02-07-2006 06:26:41
what is a good sparkplug to use in an A ?
frank van den dorpel
02-07-2006 18:05:26
 Re: 1942 JD A in reply to frank van den dorpel, 02-07-2006 06:26:41
thank u all for your response.i think i will go with the 388 autolite
Glen in TX
02-07-2006 21:25:52
 Re: 1942 JD A in reply to frank van den dorpel, 02-07-2006 18:05:26
If you got a battery distributor 388 will be fine but it and the Autolite 386 are resistor type and shouldn't be used with a magneto. With a magneto try Autolite non resistor plugs 377 or 378 which cross to Champion D21 & D23 or AC C88 or C88L and those are all non resistor type better for mags.
buckeye al
02-07-2006 14:48:56
I use Champion D23's for light use (parades etc) and the D21's in working tractors. No complaints here.
40 years ago many used the Champion D16's as the standard plug but today even Champion's book says the D16 is only for heavy use!
DW
02-07-2006 08:53:13
I always use AC C87 plugs.
Mike M
02-07-2006 07:00:03
I always had good luck with auotlite # 388
