Help with 400 brakes
Stan Garrett
02-07-2006 03:46:56
I have a 400 loader/backhoe with no brakes. From previous posts I see I may have a problem with the equalizer valve ( I capped the brake lines but the master will not build pressure and all the fluid in the res is dissappearing somewhere).Where is this equalizer valve and can it be serviced with the master on the tractor? If it has to be removed, what is the trick since the master is held on by two studs with not enough room to slide it off? I've got a manual ordered from IT. Will this be covered in the book? Thanks for any help
