What application for 1275 wheels?
960
02-06-2006 19:17:04
Where are 1275 wheel rims used? I am aware of 1262, 1268, 1274, and 1290 but where do 1275 fit in?
Duane Larson
02-06-2006 21:49:21
 Re: What application for 1275 wheels? in reply to 960, 02-06-2006 19:17:04
960,
The JD1275R was a non-reversible wheel which used a 4.25K-16 rim. It was found on AW, AR, AO models, and was a heavy duty version of the earlier JD1261R, which it replaced sometime between 9/45 and 3/47. It used either a 5.50 or 6.00-16 tire, probably 6-8 ply. The problem with identifying it is most of them are not stamped - at least I haven't found one stamped. If the tire is off, the bead-bead distance of 4 1/4", plus being non-reversible, is the key to identification.
960
02-07-2006 12:52:37
 Re: What application for 1275 wheels? in reply to Duane Larson, 02-06-2006 21:49:21
Thank you for your answer and sharing your wheel expertise. My pair is stamped which is the only way I could find out. Have never seen any before now since they went on the models you listed and I am in Midwest corn soy area it all fits.
