4020 pto wont stop
mattd
02-06-2006 17:52:13
i just got this '64 4020 gas powershift and i have noticed that the pto wont stop turning. it doesnt just barely move but moves the same speed as if it was engaged. my newer 4020 disel with syncro does a little of this, but it hardly turns and if i hook somthing up to it, like a shredder, it stops. any help will be appreciated
DaveH IA
02-07-2006 06:58:05
 Re: 4020 pto wont stop in reply to mattd, 02-06-2006 17:52:13
The first thing to check is the linkage as JD said If that don't fix it it needs split "twice" you have to split at clutch housing and remove clutch pack to get 2 bolts out to split under floor board then lots of lines shift valve etc I had one down last winter the tractor had run awhile turning all the time and once the faceing is all gone off the brake you have metal on metal and the grindings get in the brg. and gears dealer wanted 4000 to fix it--it can ruin the center housing where the brake sets by spinning in the casting
JD @ Antique Acres
02-06-2006 18:27:04
Two things that I have run across on my own 4020 with the same problem is 1) it could be the pto brake which would require it to be split to be fixed, 2) underneath the steering column follow the linkage to the main case there is a "dog legged" shaped piece that could be worn or loose which won"t allow full movement of the linkage to fully disengage the pto. This would be a inexpensive repair, the other is not.
David from Kansas
02-06-2006 18:17:23
I've got a 65 model PS diesel with the same problem. My mechanic son tells me that the brake is shot and tractor has to be split to fix. Mine will not turn with a light load so I just live with it. I have to shut down the engine to connect/disconnect the PTO. About the only thing I use PTO for is grinder/mixer.
