1936 D problems
Douglas Conrady
02-06-2006 12:56:59
We just finished redoing my d's manifold. We had the manifold planed, put new gaskets in and redid the bearings in the fan shaft. Ok, now here is my problem. When it is running it still lets off white smoke out of th exhaust stack when it pops. It does back fire once in a great while. It also doesnt have a steady idle. We think maybe the carb isnt adjusted right. Does anyone have any suggestions?
Please email me @ [email protected]
Thanks,
Douglas
Cleatus
02-17-2006 11:39:52
 Re: 1936 D problems in reply to Douglas Conrady, 02-06-2006 12:56:59
I had the same problem. The shop manual and the owners hand book disagree on the preliminary idle setting. When I set the Idle screw to 2 1/2 turns like the hand book said, it ran great. The shop manual says 1 1/2 turn and thats wrong for a D.
Glen in TX
02-06-2006 13:30:57
You shouldn't have any backfiring on that 36 D though it does happen on the early Ds no matter how good you think you got them set. I would suspect the carb because you said no steady idle or ignition problem possibly but would also check the valves for one sticking or a bad spring. Also make sure you have a good steady flow of gas to the carb. Initial carb settings for the D will be for Idle = 1 3/4 to 2 1/2 turns open and Load = 1 to 1 3/4 turns open. How long has it been since this tractor ran? If a long time take the 2 pipe plugs out on top of the rocker cover and squirt something on the valve stems to lube and unstick them, kerosene oil mixture, Marvel Mystery, or penetrator fluid.
Douglas Conrady
02-06-2006 13:57:15
 Re: 1936 D problems in reply to Glen in TX, 02-06-2006 13:30:57
Glen,
Thanks for your help. It gets to run several times over the course of a year. Last time it was run as about 4 months ago. My dad thought that maybe the carb float may not be set right. Could this be a cause of the problem? Does the white smoke mean it is running too rich?
Thanks again,
Douglas
Glen in TX
02-06-2006 19:33:36
 Re: 1936 D problems in reply to Douglas Conrady, 02-06-2006 13:57:15
Doug, You can get a 1/8" NPT hose barb fitting and some clear plastic tubing holding it along side of the carb bowl with tubing at the top line of bowl and when filled with gas it should be about 3/4" from top of the bowl. With carb and bowl off dry the float should be about 3/8" from bowl edge. May want to check the float for leaks or pin holes if it is flooding to much or just take the carb off and give it a good cleaning and kit and gaskets is that hasn't been done in a while. You need to clean out all the passageways well and drills to do that are available from Roberts Carb and others. Might try pulling the intake loose also before pulling carb and see if that helps clear it up any and if it does suspect to clean out the air cleaner and stack well. Probably some plugged passage ways or needle and seat leaking too much or float leaking if flooding still then. You can hold your float with a pair of pliers in a pan of warm water (not boiling) and will see air bubbles spewing from any holes in it. Those can be soldered if you're good at that and filed down or new floats are available too.
