I would adjust the length of rod between the governor and the carb first. With the engine stopped, remove the rod from the carb and place the throttle handle in fast idle position. All the way forward. Holding the throttle shaft on the carb in the wide open position, the rod should be half the diameter of the rod short of droping into the hole. If once adjusted it still won't run up to speed, check the governor spring. With the engine not running and throttle handle pulled almost all the way back (maybe just an inch forward from the dead slow idle position) and the carb anywhere between the idle and wide open stops, the spring should contact the nose of the governor arm. If not, remove the spring and inspect it for bends, cracks and rust particularly up at the attachment end. The spring may simply need to be replaced. Shortening the rod more than a half a hole is effective but doing so is working around the real problem. It will increase the speed of the engine but it will not necessarily increase governor action, stability and sensitivity. What you do to get your RPMs up sort of depends on what you want to do with the tractor!
