'49 A Clutch rebuild
Dave in SV
02-05-2006 09:49:28
I am going to tear my clutch down and rebuild it. The exploded parts diagram will help, but is there something out there that shows a better assembly order? Once I get into it, it will probably be self-explanatory... but I'd like to review what I'm getting myself into before I get myself into it!
BushogPapa
02-05-2006 10:33:25
 Re: '49 A Clutch rebuild in reply to Dave in SV, 02-05-2006 09:49:28
Word of advice..Never Force the 3 clutch bolts..you can break the clutch drum, if you do..
Pretty self-explanitory, once you are in there, and the clutchdriver is off.. Chect the condition of the 3 pivots and the Clutch-dogs on them for any damage.. Be sure to use high-temp grease on the clutch sleeve and clutch bearing...there should be a grease fitting to grease the clutch-sleeve..grease until grease appears at all clutch toggles..(the short little rods).. Use anti-seize on the clutch bolts..
Ron..
Dave in SV
02-05-2006 11:57:41
 Re: '49 A Clutch rebuild in reply to BushogPapa, 02-05-2006 10:33:25
Excellent info... thanks!
