4020 selenoid
fudpucker
02-05-2006 08:19:10
I just replaced the selenoid on my 4020D. The one that was on it had been on there for two years. I started the tractor a few times (3-4) with no problem. The last time (yesterday) when I hit the starter, the seleniod would not disengage. I have limited knowledge of how this works so I guess my question is this a seleniod problem or something in the starter that caused this. Also if anyone wants to buy a 4020 cheap this one is going to be for sale with alot of new parts. Thanks in advance for you replies.
Fudpucker
02-05-2006 12:11:21
 Re: 4020 selenoid in reply to fudpucker, 02-05-2006 08:19:10
Thanks guys. I appreciate the response. I'll gete on it Monday. I apppreciate it!
msb
02-05-2006 11:58:27
Inside the solenoid cap is the round contactor button (about the size of a 50 cent piece)and a small pointed contact that the contactor button engages first when the starter is engaged.This powers the coil that pulls the starter drive rearward and the drive gear engages the flywheel teeth before the starter starts to spin.This keeps the drive from chewing up the flywheel teeth.The next thing to happen is the main contactor button engages the two large contacts that power the starter motor and causes the starter to spin the engine.This all happens ---boom-boom and the sequence is not easily heard.If the starter spins the starter motor but does not engage the drive then the problem is in the small pointed contact.But in your case the button has welded itself to the two large contacts.One from the battery and one going to the starter motor.If is usually a low battery that causes the contacts to weld as a rule.(Why? I don't know,maybe Bob knows)
On some solenoids the contactor plate can be reversed and the other side used if the original side is badly pitted. Remove the nuts (small ones too)to the bolts on the end cap (after disconnecting the battery of course) then remove the solenoid end cap.Be sure to save the rubber insulators in the cap.If the contact button is reverseable, swap sides and then file down both of the other two copper contacts.Finally be sure to check to see the small contact protrudes to where the contactor hits it first.I have a 3020 of my own that needs this fixed and it causes the starter to try to spin and engage all at the same time.Overloads the starter when it does that sometimes. Sounds REAL bad.clunk-clunk lol,bob
Bob
02-05-2006 12:05:21
 Re: 4020 selenoid in reply to msb, 02-05-2006 11:58:27
MSB,
I don't believe the little contact you mention is present in the correct 24-Volt solenoid.
This solenoid is different than most, in that BOTH ends of the solenoid's "hold" winding are brought out, at the 2 small terminals.
The other "pull-in" winding has one end connected to the "S" terminal. and the other end internally connected to the solenoid's large output (to the starter) stud.
If a standard 12-Volt solenoid OR an incorrect 24-Volt solenoid with the "hold" winding grounded to the case is used, the solenoid will latch in, and "stick" as the original poster's did.
Bob
02-05-2006 08:38:15
Original factory 24 Volt?
24 Volt converted to 12 Volts, with an extra solenoid ahead of the starter solenoid?
Original factory 12 Volt?
Did just the starter keep running, or did it stay engaged with the flywheel, and continue cranking the engine, (or grinding against the flywheel ring gear, if the engine started)?
How did you get it to stop... tap the solenoid, or disconnect the battery cable?
Was the rubber sleeve dust seal that slides over the nose of the solenoid in good shape, and did you get it properly in place when you installed the solenoid?
fudpucker
02-05-2006 11:44:48
 Re: 4020 selenoid in reply to Bob, 02-05-2006 08:38:15
Bob,
It has two 12volt batteries and an alternator with both battery hot wires going to the starter and each battery grounded seperately. I tried to tap the selenoid , but that didn't work. I disconnected the battery cables. The dust cover was fine and everything was installed properly. It kept trying to turn the engine over, it wasn'tjust spinning the starter. I am beggining to wonder if I am getting the correct selenoid from the parts store or if it is a different starter than is supposed to be on the tractor and they aren't matched correctly. It has always started a little slow like the batteries just barely have the juice to turn it over even when the batteries were brand new. It has been like this since I have owned it. Once it's going it runs great. It's just getting her going. I bought it burned and the guy I bought it from didn't remember much about it. Any ideas?
Thanks alot!
Bill-NNY
02-06-2006 02:22:40
 Re: 4020 selenoid in reply to fudpucker, 02-05-2006 11:44:48
comments and questions:
Are the 2 leads from the battery connected to the solenoid or is one on the starter? Does the starter have a name(ID) plate? Do you twist the key or push a button to engage starter? Does the tractor shut down with the throttle or key switch? Are the two "hot" leads to the starter the same polarity? If a POS and NEG cable are at the starter it is 24 volt.
A late model 4020 could have been changed from 2 six volt batteries in series to 2- 12 volt batteries in parallel.
A slow cranking engine with fresh batteries and good connections could mean a weak (tired) starter or a hydraulic pump load.
Fudpucker
02-06-2006 04:46:00
 Re: 4020 selenoid in reply to Bill-NNY, 02-06-2006 02:22:40
Bill,
Both hot battery cables go to the selenoid. The tractor starts with a push button and shuts down on the throttle. I don't know about the id plate as the tractor is on another farm.
Thanks
Bob
02-05-2006 11:59:53
It sounds like it is as-original 24-Volt.
If so, you need the correct 24-Volt solenoid, in which the solenoid coil is isolated from the metal case.
You can't tell if the solenoid is correct, or not, by it's appearance.
The correct solenoid (re-man), #TY6689, is less than $30.00 at your Deere dealer.
The outermost small terminal on the solenoid will be connected to a yellow wire from the neutral start switch, and the other little terminal, closer to the engine block, will be connected to a (white?) wire from the big stud on the engine block side of the starter "belly", where the (+) battery cable connects.
Your 24-Volt 4020 wiring will be SIMILAR to the 4010 information, posted by Gary Wece at the link below.
Bob
02-05-2006 11:59:44
