JD 2940 Loader
HarryO
02-05-2006 07:15:14
I am looking for a loader for my JD2940 4WD. Does anyone know where I can get a Deere loader or aftermarket loader that is good quality.
Thanks.
Walter Squires
02-06-2006 06:42:26
 Re: JD 2940 Loader in reply to HarryO, 02-05-2006 07:15:14
You will need braces that go from the loader mount to the rear axle housings. Waterloo tractors didn't need them but Manhiem tractors did. A tractor broke in two is not a pretty sight!
HarryO
02-06-2006 08:01:22
 Re: JD 2940 Loader in reply to Walter Squires, 02-06-2006 06:42:26
Thanks for the information. How can you determine where it was made?
Bob F.
02-06-2006 04:28:31
Just a word of caution. Years ago we purchased a 2940 4WD new and wanted to put a 148 loader on it. We already had the loader from the tractor that we traded in on the 2940. The dealer at that time initially told us it wouldn't work on the new tractor. After some further checking, he said that it would work but that they would have to make some modifications to the mounting brackets. We have long since sold the tractor and I don't remember exactly what they had to do. I don't think it was anything too radical, maybe just drilling some new bolt holes. If you get it to work, you'll have an awesome combination. Ours was the best tractor/loader combination that I have run before or since. You might want to research this a little further or maybe ask a dealer that has got some service guys around from the early 80's.
Hope this helps.
Bob F.
mitchp
02-05-2006 09:31:29
if you'll go to ebay and search for "john deere loader" you'll see some there, there was a JD 148 on there that looked pretty good. you could put a new woods loader or bush hog on it that will be quick attach for not much more than you'll spend on a good used loader.
