60 Powr-trol
rich2
02-05-2006 06:12:16
I am having trouble with the slow down position of the Powr-trol on a JD 60 tractor. The rockshaft arms work good but when I change the coupling plugs to use the loaded the slow position does not work well. In the slow down postion the engine labors and the loader seem to build presure on both side of the cylinders and the loader barely goes down. I have adjusted the two metering and throttle value screws but it does no seem to fix the problem. I have also taking the relief valves apart and inspected them and the springs, balls, etc, look good and clean. Any advice would be appreciated.
Mike M
02-05-2006 07:59:17
 Re: 60 Powr-trol in reply to rich2, 02-05-2006 06:12:16
I had a JD 50 with a #45 loader and had it plugged in the back with the couplers you normally use for cylinders. I had the same problem as you described and it did not want to lower smoothly with a load on it. Went back to the books and they showed those loaders plumbed into the side ports on those boxes. Rehooked it up as shown and it worked smooth as silk.
55 50
02-05-2006 12:31:34
 Re: 60 Powr-trol in reply to Mike M, 02-05-2006 07:59:17
Mike,
I suppose you are referring to the photos on page 13 of the Operator's Manual, OM-C13982C. Then do the plugs that are in the rear holes need to be the type used to make the rockshaft operate, or doesn't that matter?
The right bottom photo on page 13 shows the couplings at the left of the Powr-Trol unit. The lines then must come around from the side outlets in front of the battery box to appear on the left of the P-T unit, correct?
Mike M
02-05-2006 19:48:29
 Re: 60 Powr-trol in reply to 55 50, 02-05-2006 12:31:34
I do not have any of my manuals at hand. The rockshaft plugs need to be installed. You can just put elbows out of the right hand side pointing back and then use a pioneer coupling on that so you can unhook them. What happens is that since the rockshaft is of least resistance (even when the 3pt. is on it )it will raise up first then stay up as you run the loader. I ran my 50 this way for many years. I just left the 3pt. on for extra weight. I was able to rig up a selector valve to where I could raise up the loader then flip it and then the loader stayed up alittle while I used the 3pt.
Dan in Ohio
02-05-2006 06:35:04
Rich, Are you making the required metering screw settings for the hydraulic cylinder operation as the manual states, you should not have to touch the throttle valve screw?
Rich2
02-05-2006 08:12:40
 Re: 60 Powr-trol in reply to Dan in Ohio, 02-05-2006 06:35:04
Dan in Ohio, I have tried leaving the throttle value in its original poition and closing the meter value down tight but no change. What do you think of running the lines out the side. Do you beleive that would work?
Dan in Ohio
02-05-2006 10:06:04
 Re: 60 Powr-trol in reply to Rich2, 02-05-2006 08:12:40
Rich, I have a 49 A with a 45 loader on that uses the same pugs as the cylinder and it works fine but Mike would know more than I do. Also look at your hydraulic plugs as there are several variations, some are hollow with open ends some have holes at the mid-point, some are selector valves, you may simply have the wrong plugs. Give Mikes idea a try, it would be an easy solution if it works.
