B Pistons
Bill Dorrance
02-04-2006 17:30:30
I have decided that it is time to replace the pistons and overbore my 44 B.
Does anyone have a preference or had good experience with any particular brand??
Mike M
02-05-2006 08:10:52
 Re: B Pistons in reply to Bill Dorrance, 02-04-2006 17:30:30
I guess it also depends on what you are going to use this tractor for ?
If you want to keep it original so you can still burn kerosene then you are going to have to find a set of original style cast iron oversized pistons or reuse the ones you have and sleeve the block.
If you want more power and if you can find a set of the JD cast iron pistons made for these to run on gas only then these will perk it up alot. Someone may be reproducing these in aluminum today ?
If you want more power yet if your block will take it without hitting a thin spot or sand hole you can use some pistons from a late model B ser # 201,000 and up. If you do this you may as well put in the cam from the late model also.
And then for more yet I've seen some with a late model power block stuck in them.
Lynard
02-05-2006 06:06:18
Bill M&W pistons for the late B work. They are 3/16 overbore and taller for more compression. Don't remember exactly what you get. Can shave head and block some for more. Wrist pins same diameter and head gasket will work. Lynn
