1010 ignition switch
Loren NC
02-03-2006 14:56:29
My 1010 quit on me the other day out in the pasture. Found a lug broken off the back of the ignition switch. Two days later I studied the lug configuration carefully before I went to pick up my new ($50) replacement switch so I would know I was getting the right one. However, my old one had six lugs on it and the new one had seven. When I actually pulled the old one out, I could see where the seventh one had been at one time. Anybody have any idea what the one lug is for that stands alone on the opposite side of the switch from all the other wires? Interestingly, it also has a female wire lug where the other six are all male.
jdemaris
02-03-2006 17:33:13
 Re: 1010 ignition switch in reply to Loren NC, 02-03-2006 14:56:29
I don't know if the switch you pulled out was original, and I have no idea what Deere is selling now as a replacement at this time. But, it should be pretty easy to figure it out. You didn't mention if it's a gas or a diesel - there's a big difference. The original gas engine switch, when the 1010 was new, had an ignition resistor built right into it, and also had a built in resistor bypass when in "start" position. Deere stopped selling those Indak switches around 1978 and replaced them with another switch that still had the bypass, but used a remote-mount resistor kit. If you have a gas engine, and also have a Delco starter (not a Prestolite), you don't need to use the bypass in the switch. But, I don't know if you have gas or diesel, and I don't know if it's an early or late 1010. Early has the shifter in the dashboard.
Loren NC
02-06-2006 14:30:51
 Re: 1010 ignition switch in reply to jdemaris, 02-03-2006 17:33:13
My old switch and the new one have a built in, but visible, resister on one of the lugs in the back.
The tractor is gasoline, 1963 according to the serial number. Shift is on the housing in front of the seat.
