1010 Crawler with Reverser
Salty
02-03-2006 13:56:33
Am working on bringing a 1010 crawler back to life. It has a reverser on it. Someone welded a plate over the slot that has 2nd and reverse on it on the dash. I understand why you would not want to use the reverse but why does the plate preclude using 2nd gear also?
CH
02-04-2006 21:53:09
 Re: 1010 Crawler with Reverser in reply to Salty, 02-03-2006 13:56:33
email me and i will send you a link I have New and Used parts for that machine
jdemaris
02-03-2006 17:41:25
The transmission has nothing to do with the reverser. Also, there is no reason why you can't use the reverse in the gear transmission. In fact, when doing heavy work going backwards, like back-blading, you are MUCH better off leaving the hydraulic reverser in forward and putting the gear transmission in reverse. It sounds like there something wrong with the gear transmission or shift linkage and someone's blocked off access to those gear slots. The hydraulic reverser is weak in reverse with all the 1010s and early 350s - unless it's been rebuilt and beefed up with a larger input shaft/clutch drum and bearings. Sounds like you've got a very early ca. 1960 1010. Deere kept the gear-reverse in all the 1010s, and also all the 350s until the "C" series came out. By then, the reverser was no longer an option - it was standard equipment and had been made strong enough that Deere decided to save a few bucks by leaving reverse gear out.
