JD 2950 steering problem?
MattF-8
02-03-2006 10:21:16
I have a chance to purchase a 1987 2950 2wd with 1585 original hrs. In checking the tractor out(while running) the steering wheel will turn the tires all the way to the stop in either direction, but if you continue to apply pressure to the steering wheel it will continue to turn. I am correct in assuming that there is problem within the hydraulic steering? If so, what potentially could be the problem? How costly would it be to repair? Thanks for your advice!
Matt
feelnrite
02-03-2006 11:25:48
 Re: JD 2950 steering problem? in reply to MattF-8, 02-03-2006 10:21:16
I have a 2955 with 3400 hours on it and I think it will do that and always has. I bought it new in 1991. I have felt it do that I am almost sure but I never keep pressure on it when it does. With the number of hours on the tractor that you say it has it should have no problems.
