B water pump
Mister B
02-03-2006 09:26:15
What is it that makes the coolant water in a late model B (1948) circulate? I do not see a water pump at all. The fan shaft comes out of the govenor housing but I do not see how it can circulate water to cool the motor. Thanks Mr.B
in-too-deep
02-03-2006 12:39:13
 Re: B water pump in reply to Mister B, 02-03-2006 09:26:15
It's called a Thermosyphon system. Colder water enters the block through the lower water pipe. It is heated in the block and rises towards the upper water pipe. The hotter water travels up the pipe and into the radiator where it is cooled. It flows down the radiator and back into the lower water pipe. No thermostat either, it uses shutters on the radiator to keep cool air from flowing through the fins instead of a thermostat to control the water. Really kind of a neat system, but it was replaced by a water pump sytem in the 50's.
Dave NE IA
02-03-2006 09:42:25
Just like your coffe pot purculator- the hot water circulates on its own. They many times put water pumps on the 2 cylinders when they put mounted picker on them. Dave NE IA
