Converting gen to alt
Dustin McCubbin
02-03-2006 07:03:45
Sorry for not giving enough info. It is a deisel engine with 2 12volt batteries on each fender. the Alt. is actually a 10si (discovered this today). Today is the first time I actually tore into the tractor. Who ever converted it before run a wire from the large stud to where the battery cable goes on the starter solenoid. Should it be run to the positive stud on the starter body itself? I am also not sure if it has been converted to negative ground or not. I traced the battery cables and the positive cable from the left battery went to the solenoid and the cable on the positive post of the starter went to the negative of the right battery. When the starter button is pushed it will attempt to start (bad batteries I think), so i believe this system will start it if the batteries where good. I put a multi-meter on the post on the alt. and had no output voltage. Should this be the case or does it only produce voltage when a load is applied? I do have a service manual for this tractor with wiring diagrams. Please email me your responses if you can. This site will not come up at the shop.
[email protected]
Thanks
Dustin M.
buickanddeere
02-03-2006 23:55:58
 Re: Converting gen to alt in reply to Dustin McCubbins, 02-03-2006 07:03:45
It's not impossible yor altenator was rebuilt with a 24v regulator. Some were even built to float the output isolated from chassis. In any case it will have to come apart to find what lurks inside. Ken at Classic Generator can build a high output 18 amp 24V generator which is a step up from the factory 10 amp 24V. The 18 amp units were used on the later 840's.
55 50
02-03-2006 09:58:49
from what you stated "2 12 volt batteries on each fender" that would make FOUR batteries. Is that really what you have?
Dustin McCubbins
02-03-2006 15:03:38
 Re: Converting gen to alt in reply to 55 50, 02-03-2006 09:58:49
Sorry, that would be 1 battery on each side. Im glad it is not 4 total or I would be in a terrible mess
buickanddeere
02-03-2006 07:09:12
Does the starter have one heavy cable connected to it's soleniod? Or does it also have a 2nd heavy cable bolted to a large stud on the side of the starter motor it's self. We are going to have to figure out what you have 1st. Sounds like somebody before you certainly did something??? I have even heard of some crude hacks keeping the 24V starter but using a 12v alternator. They swap the cables to 24V start then swap again to charge both batteries with 12V.
Dustin McCubbins
02-03-2006 08:07:10
 Re: Converting gen to alt in reply to buickanddeere, 02-03-2006 07:09:12
It has one cable on the solenoid and one on the large stud on the side of the starter motor.
jdemaris
02-03-2006 17:51:11
 Re: Converting gen to alt in reply to Dustin McCubbins, 02-03-2006 08:07:10
If the "ground" cable is hooked to a large stud on the side of the starter, it is a groundless isolated 24 volt starter. If you look closely as the Delco solenoid, you'll probably see 24V on it.
If this is the situation, you've got a bunch of mismatched components. The tractor originally had a Delco-Remy custom designed 24 volt non-grounded starter along with two 12 volt systems - one neg. ground and the other pos. ground for the tractor electrical system. To work correctly with the original design, the starter has to remain isolated, and the 12 volt alternator won't do. If someone modified the basic electrical system to a single, neg. ground 12 volt system, and put a special series-parallel switch in, it could be made to work witha 24 volt starter and a 12 volt alternator - but your's just sounds like a mess of mismatched parts. So, seems you have to sit back and make a decision on which way you want to go, get parts that can work together, and then commence to getting it wired.
