JD 146 Loader - questions?
Dan C.
02-02-2006 13:37:11
The boom section will "slowly" go down with or without a load. I have taken apart the double operator valve and its all machined ports with nothing inside looks it could be worn or wear out.
Any ideas - cyclinder leaking?
What have you found and fixed this same problem? Thanks.
Dan C.
Nylon
02-03-2006 17:38:34
 Re: JD 146 Loader - questions? in reply to Dan C., 02-02-2006 13:37:11
Sounds like the piston seal to me. Sometimes you can hear fluid flow with the boom raised and tractor shut off if it is at the valve. I just replaced my piston seals and rod holder rings / bushings. My seals were shredded and I can't believe that it actually lifted anything. The loader would bleed down on occasion and other times it wouldn't. Taking cylinders apart isn't too tough. Worst part is corraling the hydro fluid as you unplug and undo them. The worst part about the 148 loader was getting the circlip retaining rings onm and off. A schwarts loader I did had a wire feed into and out of a hole while rotating a nut cap. That was much slicker.
John
