JD 1140 Hydraulic Problem
William Jessip
02-02-2006 07:49:56
Our maintenance team is working on a 1999 John Deere 1140 tractor, ser# 499364 with a hydraulic mystery. Whenever the hydraulic reservoir is filled, all the fluid ends up in the transmission and does not circulate back to the reservoir. Unfortunately, the service manual previously placed on order is still due in. Any advice would be greatly appreciated. Thank you in advance for your time and consideration.
buickanddeere
02-02-2006 12:59:07
 Re: JD 1140 Hydraulic Problem in reply to William Jessip, 02-02-2006 07:49:56
What reservoir? Sounds like something extra has been tinkered onto the tractor? What kind of hydraulic equipment is used with/on the tractor? The transmission is supposed to hold the hydraulic oil. What kind of lubricant has been added to the transmission? And what kind of oil has been dumped into this reservoir?
William Jessip
02-03-2006 01:37:01
 Re: JD 1140 Hydraulic Problem in reply to buickanddeere, 02-02-2006 12:59:07
The reservoir is located in front of the radiator/cooler. It hold about two gallons of fluid. I have some digital pics but can't seem to be able to add them to this message. The tractor is used primary to tow helicopers into the maintenance hangers. We have two of the 1140's and two 855 JD's. We are using 10W hydraulic fluid in the reservoir and transmission.
