320 steering shaft
Hayfarmer
02-01-2006 20:01:16
I am working on a neighbor's 320U. There is about 1/8 turn or better slack in the steerig wheel. Checked gerbox and it was fine, lslack is between front end of steering shaft where it mounts to the worm gear. Looks like at some point it got loose and turned so it wore out keyway in the coupler on shaft. To make matters worse the steering wheel end of shaft looks like someone welded the nut onto it. Best fix would be to get new steering shaft and it looks like the 420 U has the same shaft(one piece). Wondering about building up the inside of the coupler. Has anyone got one of these shafts or had experience building it up?
jCarroll
02-03-2006 18:24:29
 Re: 320 steering shaft in reply to Hayfarmer, 02-01-2006 20:01:16
If you're not concerned about pretty - or "just like new", drill a hole straight through the coupler and the worm shaft. Put a 1/4" spring pin through the hole.
When you finally decide to remove the steering shaft, cut it in two someplace where you have room to work - between the gas tank and the block. Take the end with the steering wheel off to your shop where you can work on it. Then reassemble, and repair the cut joint however you think best.
