Elk, for the float level to be set so high that raw gas reaches up into the carb throat and the piston draws in pure gas (floods and wont start) that would be like reallyyyyy yyyyy highhhhh hhh and so high gas would keep running into the air pipe and manifold. Its awful difficult and Im not sure if its possible for the float and needle valve n seat assembly to alllll ll be working without still shutting the gas off sometime BEFORE it reached such a high overflow. It would have to have its lil adjusting tab bent to the max to still not shut gas off BEFORE it got so high it ran over. I guess it may???? be possible to set a float that high, but I just cant say for sure????? ????? ???? If the float level is too low, there can be insufficient gas for a heavy load or she may sputter when you crack the throttle wide open cuz theres not enough gas in the well. If the float level is too high (But still works and shuts gas off BEFORE it reaches spill over levels) she may run but too rich and black smoke and gas foul the plugs. I think the more common problem of flooding is not so much the float level is incorrect, as that theres dirt or gum or varnish or a problem in the needle n seat area and the gas dont get shut off at the correct or ANY level whatsoever thus allowing it to rise and overflow into the manifold n air inlet pipe. Usually when they flood badly and/or raw gas drips over and is in the air pipe and gets into the manifold, I look for a needle valve n seat problem instead of the float level not being exact. Sooooo ooo Yesssss sss the float level can be set correct BUT it can still flood if the needle n seat arent shuttign the gas off whe the float gets to that particular level. I.E. The floats at that correct level where the needle ought to be into the seat and stop the gas, but it dont and she floods. Make any sense????? John T
