1951JD B block
Ivan in Mich
02-01-2006 17:27:45
I am starting to put my engine together and a short while back I read a post that said there was an oil line running into the block. I did not unhook a line when I took it apart. I have a line from the pump to a fitting on the crankcase that lines up with a hole in the block but no line. Should there be a line running into the block or not. I would like to get it right the first time if possible.
Mike Aylward
02-01-2006 18:45:34
 Re: 1951JD B block in reply to Ivan in Mich, 02-01-2006 17:27:45
Ivan, on your late B there is an oil line going to a fitting screwed into the front of the main case. Instead of an oil line going forward from here there is a passage cast into the block to go to the rocker area to provide lubrication. Earlier tractors have a line here but yours does not. Just be sure there is a line connected to the fitting before installing your block. Hope this helps. Mike
greenmech
02-01-2006 18:37:11
There should be a fitting or line that runs thru the block to connect with the tappet oiler fitting. The parts book doesn't show this very well,but you do need to get the oil to the valve area. Ron Mn.
