3010 load control shaft
woodbutcher
02-01-2006 05:36:01
Well, once again, I'm going to have to replace the seals on the load control shaft. The leak has become serious. This time I'll replace the shaft too. There's a machine shop in Missouri that sells the shaft cheaper than JD factory replacements, and they say they have a solution to the seal leakage. From what I read in the archives, it seems to be a more involved process than replacing seals. Does anybody have any experience with this new method? Is it better than the old $5.00 seals?
Butch
joe 1206
02-01-2006 20:16:57
 Re: 3010 load control shaft in reply to woodbutcher, 02-01-2006 05:36:01
make sure you shim the wishbone as tight as you can get it. so you dont have any side movement. i have installed alot of those seals over the years and learned that lesson the hard way.
msb
02-01-2006 08:39:17
Repeated failures of the seals indicate that the bushings in the wishbone need replaced,especially the one in front usually.
woodbutcher
02-01-2006 13:34:13
 Re: 3010 load control shaft in reply to msb, 02-01-2006 08:39:17
Thanks, that could be the source of my problem.
Butch
woodbutcher
02-01-2006 08:21:58
Thanks Mike and Don,
I suspect the shaft is as old as the rest of the tractor, and it's time for it to go.
Butch
Mike M
02-01-2006 06:52:51
I put a set in our 4020 over 10 years ago and still no leaks. It has a 9' blade hooked on the 3 pt all the time.
donmyeil
02-01-2006 06:42:25
one thing I learned over the years is if the shaft is over a year old replace it. Also replace the bushings as the seals can only flex so far and when the bushings are worn the seals wont last. I personaly dont care for the so called aftermarket seals and bushings. The stock bushings are not wide enough let alone cutting a grove in them so they will wear faster.
