Converting gen.to alt.
Dustin McCubbin
01-31-2006 17:58:36
I work for Tennessee Wildlife Resources Agency and we have a 3020 that someone has tried to convert to an alternator. The system is not charging correctly. It has a single wire Delco alt. on it but is not hooked up for some reason. The tractor is still positive ground I think. I need to know what to do to get it to work. Can some one please tell me what I need to do to make the system charge.
Thanks
Dustin
Dustin McCubbins
02-01-2006 18:57:46
 Re: Converting gen.to alt. in reply to Dustin McCubbins , 01-31-2006 17:58:36
Sorry for not giving enough info. It is a deisel engine with 2 12volt batteries on each fender. the Alt. is actually a 10si (discovered this today). Today is the first time I actually tore into the tractor. Who ever converted it before run a wire from the large stud to where the battery cable goes on the starter solenoid. Should it be run to the positive stud on the starter body itself? I am also not sure if it has been converted to negative ground or not. I traced the battery cables and the positive cable from the left battery went to the solenoid and the cable on the positive post of the starter went to the negative of the right battery. When the starter button is pushed it will attempt to start (bad batteries I think), so i believe this system will start it if the batteries where good. I put a multi-meter on the post on the alt. and had no output voltage. Should this be the case or does it only produce voltage when a load is applied? I do have a service manual for this tractor with wiring diagrams. Please email me your responses if you can. This site will not come up at the shop.
[email protected]
Thanks
Dustin M.
John T
02-01-2006 06:59:47
Dustin, most alternators are for Negative Ground, so the tractor will have to be configured that way for it to ever work in the first place and not damage it (maybe that already happened???). Next, is it really a true One Wire alternator or a GM 10 SI (two lil spade side terminals and big main outpit stud on back) which is in reality a 3 wire alternator that can be made to work fine if properly excited. Is the tractor a gas or diesel and what voltage, 12 or 24 (two 12 volts in series like some diesels used)
Sorry more question then answers but we gotta know this to help.
John T
Glen in TX
01-31-2006 21:49:24
Some good info for Delco 10SI alternators at this link under tech info.
jdemaris
01-31-2006 19:53:28
Need a little more information. Is the 3020 a 12 volt or split-24 volt system? Is the alternator a Delco 10 or 12 SI? When you say it is "one wire", does it have a top mounted harness plug or back mounted, and is the plug not hooked to anything?
