Before I do something I'm going to regret.........
GreenLover
01-31-2006 16:34:48
I'm in the middle of my first John Deere restoration. Although this is just a cosmetic resto, I have never taken any tractor this far in disassembly. It is a 1958 820 Black Dash. The only components I haven't removed are the front-end, big motor, transmission, rear axles, power steer reservoir and steering column (whew!). It took a lot of work to get it this far but the results will hopefully be well worth the effort.
My question is this: Mechanically, the tractor really had no issues, except for a noisy 6th gear (quiet in the cold winter though). Besides that one issue, is there anything I should look at while I have it at this stage? Something that is prone to failure? Something that wears out after 50 years ;-) ? I would feel really stupid if I got it all back together and a day or week or year or two from now, something failed that could have been easily replaced at this time.
I appreciate any assistance. I am planning on beginning re-assembly asap in hopes of making the town's annual Winter Carnival tractor parade (highly doubtful).
Thanks very much for any help!!!
Steve
GreenLover
02-01-2006 03:46:51
 Re: Before I do something I'm going to regret..... in reply to GreenLover, 01-31-2006 16:34:48
Thanks to all for the great tips! I have some pics, but have never posted images here before and I don't know how to proceed. I will look at the areas you all mentioned. The tractor hadn't been sitting; it had been a good running and operating tractor that really just needed a good paint job (in place of the uniform brown coat of rust).
I would definately feel like I was in over my head without my buddy John. He is the real brains of this project. He's not only a mechanical and manufacturing engineer, but also worked for a few years as a body & paint man. Without him, I wouldn't have DREAMED of tackling this project. He just seems to know how everything works even though he's never owned a tractor (although I think he's been bitten by the bug now). He's even talking about restoring my Farmall Super M-TA when we finish the 820 (yes, I love'em all). Compared to the 820, the SMTA will be a piece of cake.
I will keep the group posted on progress.
Thanks again for all your help. This place definately ROCKS!
buickanddeere
01-31-2006 23:01:29
May as well check the injector's pattern the pop off pressure.
Bruce L
01-31-2006 20:21:07
If you haven't done it yet I would definately service the clutch pulley by disassembly, cleaning, repacking the roller bearing, and greasing the dogs/toggles via the grease zirk fitting in there. The roller bearing runs directly on the crankshaft and could result in an expensive repair if it goes bad. Don't be surprised if you find bonded clutch disks where the bonding agent has failed. The yoke has replaceable brass wear plates that are riveted on. If they wear out they will fall off leaving a steel on cast iron wear situation. On tractors that have sat for long periods without use you can get significant rust and pitting on the various cast iron clutch disks. Also you can get significant corrosion on the crankshaft that encroaches into the roller bearing area.
rowdy33
01-31-2006 18:27:41
1- Replace many seals, gaskets, O rings so you don't have any fluid leaks on your new paint. Fuel system is the toughest.
2- Replace the bearins in the steering post. Primarly the bottom ones. Those go bad and you never know it.
3-Simply run, operate, tune the unite before the final paint.
4-Replace bad and ugly looking nuts and bolts. simply for the better looks of fine unite.
Maby you know these things. But are over looked whats "profeshional" people do.
Mike M
01-31-2006 17:25:12
That's alot of tractor to take on as a first.
I guess it all depends on what you want in the end and what your mechanical abilitys are ?
Myself I've never really regretted tearing one all the way down because it always amazes me how many problems I find once I look.
I still can't believe that my cousin and I tore 2 820's apart at the same time. 1 clear down to an empty transmission case nothing left untouched. The other one about half way apart to use parts to fix up the restored one. He still has the restored (more like remanufactured) one and we put the other one back together and sold as a running unit. Even more amazing when I see his pictures and remember this was done back when the work shop was only something like 14 X 32
